2021-08-30 5:11 AM
I tried connecting the bno080 with nucleo 411RE using motionstudio2 window application to read the data from bno080.....
I saved the flash memory for running this application and flashed the stm with another program...
I flashed the application running bin file again in the stm...but when I am trying to connect it through motionstudio2 application it is not getting connecting . Checked all the switch ...
Is the firmware of bno080 corrupted or is the bin file error or i2c connection error.
suggest some solution...
