LPTIM pulse counter
GFont.1
I am using stm32L431, in the documentation says that when using LPTIM pulse counter the 5 first pulses is lost, after this the counter works fine. But in my project this situation is not acceptable, because in some cases I use less than 5 pulses.
I need some tip to avoid this.
Thank you very much.
Guru
Where does it say this?
