Looking for a useful debugger, such as GDB
‎2014-12-01 4:32 PM
Recently my team and I have run into a lot of issues in our code that require a good debugging solution. Unfortunately, however, we haven't found a good way of setting breakpoints and stepping through our code to find out where our issues lie.
I was attracted to GDB, since I've used it in the past for general-purpose machines (i.e. i86 architecture), but I'm fairly new to the embedded world, so I'm not sure how to use a debugger for ARM embedded processors. I installed the GNU ARM bare metal toolchain (arm-none-eabi) which includes a version of GDB specific to ARM processors, but I have no idea how to set it up properly so that I can see what's going on with my external device (i.e. a NUCLEO-F401RE board).
Could somebody please shed some light on the issue? Also, do I need external hardware like a JTAG interface in order to access information on the device (like register info or memory status), or can I do that using USB? Thanks in advance.
#basic-debugging #debugger #debug- Labels:
DEBUG
‎2014-12-01 4:44 PM
Wouldn't OpenOCD be able to use the ST-LINK (SWD) debugger on the Nucleo and Discovery boards directly?
Personally I've used Keil to debug code in the fashion you describe, including code compiled with the GNU/GCC chains, like Yagarto. I also test a lot of the more generic code, or abstract appropriately, to allow code to be debugged on PCs with PC compilers/debuggers. And understand the flow of my code, where required, in real time systems by outputting sufficient telemetry and diagnostic information via DCC, SWV, or USART channels.Up vote any posts that you find helpful, it shows what's working..
‎2014-12-01 11:27 PM
Matt,
if you are used to gdb, and run your development on *nix platform, you can use https://github.com/texane/stlink to create a remote target server. Then start GBD as usual ''arm-none-eabi-gdb prog.elf'', connect to the target with ''target remote extended-remote :4242'', load to SRAM or flash using ''load'', possibly set a breakpoint ''b main'', and go ahead with ''continue''.- Mark as New
‎2014-12-02 2:57 PM
Thank you for your responses. I think I'll look into texane's stlink software, since I don't know too much about OpenOCD and I'm avoiding expensive tools such as Keil.
‎2014-12-11 12:45 AM
maybe you could have a look at EmBlocks.
