2024-09-06 1:54 AM
I am currently working with the STM32U5G9J-DK1 development kit interfacing with a Tianma-based display. I have successfully managed to update the display using adaptive command mode with DSI long and short write commands. However, I am encountering issues related to the refresh rate and switching modes:
Request for Assistance:
Could you provide guidance on:
Your assistance in resolving this issue would be greatly appreciated.
Thank you.
Best Regards,
JAYA PRAKASH P
EMBEDDED MODULE LEAD
EMAIL: jayaprakash_p@aktisengineering .com
2024-09-10 7:40 AM
Hello @JP.4 ,
What do you mean by High-Performance (HP) mode? Do you mean High-speed mode?
For more information about REFRESH Rate and High speed mode, I recommend you to take a look at AN4860: Introduction to DSI host on STM32 MCUs and MPUs
Could you please share you project?
Thank you.
Kaouthar
2024-09-10 7:40 AM
Hello @JP.4 ,
Thank you.
Kaouthar
2024-10-17 12:12 AM
HELLO KDJEM.1
Thank you for the clarification and your assistance with my question. Your input has been constructive, and I appreciate your support. Still, we are working on it once we reach some level we will share the project for more review...
Best regards,
JAYAPRAKASH P
AKTIS ENGINEERING SOLUTION PVT LMT
2025-10-24 8:30 AM
Hi JP.4 - did you ever get a fix for your DSI problem? I have exactly the same issue myself - works in LP mode, but not in HS mode.
I scoped the line data in HS mode and the data output is actually different from that I expect, it often misses off the first byte (the ID byte from the Header).
