Is there a possibility to implement one shot function using RTC module (STM32L011)
EKore.1
RTC does not have hardware to start or do any other internal state change upon external triggers.
6 REPLIES 6
What is "one shot function"?
EKore.1
I want to create similar function to LPTIM One shot mode
that external pulse trigger (very short) cause one output pulse (width of 1 second)
EKore.1
We can't used EXTI to activate RTC down counter?
Yes you can, if you don't care about the latency/jitter this involves. In the interrupt, you can of course set RTC to whatever you want.
I don't know what do you mean by "RTC down counter" - the wakeup facility.
EKore.1
