Is the MCO signal on Nucleo boards accurate? Inaccurate PWM signal
‎2021-05-05 5:00 PM
I'm having some trouble getting an accurate PWM signal from my H743ZI Nucleo board (MB1364C). It is off by about 1%. I am not using an external crystal, I am using the MCO signal from the F723 chip on the same board.
Am I just misconfiguring something? Or is the MCO signal not accurate? I need to generate a 1 ms pulse every 128 ms.
I appreciate any help or suggestions!
#include "main.h"
#define time_sync_Pin GPIO_PIN_0
#define time_sync_GPIO_Port GPIOB
TIM_HandleTypeDef htim3;
void Error_Handler(void);
void sysclk_config(void)
RCC_PeriphCLKInitTypeDef PeriphClkInitStruct = {0};
/** Supply configuration update enable
HAL_PWREx_ConfigSupply(PWR_LDO_SUPPLY);
__HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
while(!__HAL_PWR_GET_FLAG(PWR_FLAG_VOSRDY)) {}
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
RCC_OscInitStruct.HSEState = RCC_HSE_BYPASS;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
RCC_OscInitStruct.PLL.PLLM = 1;
RCC_OscInitStruct.PLL.PLLN = 24;
RCC_OscInitStruct.PLL.PLLP = 2;
RCC_OscInitStruct.PLL.PLLQ = 4;
RCC_OscInitStruct.PLL.PLLR = 2;
RCC_OscInitStruct.PLL.PLLRGE = RCC_PLL1VCIRANGE_3;
RCC_OscInitStruct.PLL.PLLVCOSEL = RCC_PLL1VCOWIDE;
RCC_OscInitStruct.PLL.PLLFRACN = 0;
Error_Handler();
|RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2
|RCC_CLOCKTYPE_D3PCLK1|RCC_CLOCKTYPE_D1PCLK1;
RCC_ClkInitStruct.SYSCLKDivider = RCC_SYSCLK_DIV1;
RCC_ClkInitStruct.AHBCLKDivider = RCC_HCLK_DIV1;
RCC_ClkInitStruct.APB3CLKDivider = RCC_APB3_DIV1;
RCC_ClkInitStruct.APB1CLKDivider = RCC_APB1_DIV1;
RCC_ClkInitStruct.APB2CLKDivider = RCC_APB2_DIV1;
RCC_ClkInitStruct.APB4CLKDivider = RCC_APB4_DIV1;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_1) != HAL_OK)
Error_Handler();
static void tim_init(void)
TIM_ClockConfigTypeDef sClockSourceConfig = {0};
TIM_OC_InitTypeDef sConfigOC = {0};
htim3.Instance = TIM3;
htim3.Init.Prescaler = 5999;
htim3.Init.CounterMode = TIM_COUNTERMODE_UP;
htim3.Init.Period = 2048;
htim3.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
htim3.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_ENABLE;
if (HAL_TIM_Base_Init(&htim3) != HAL_OK)
Error_Handler();
sClockSourceConfig.ClockSource = TIM_CLOCKSOURCE_INTERNAL;
if (HAL_TIM_ConfigClockSource(&htim3, &sClockSourceConfig) != HAL_OK)
Error_Handler();
if (HAL_TIM_PWM_Init(&htim3) != HAL_OK)
Error_Handler();
sConfigOC.OCMode = TIM_OCMODE_PWM1;
sConfigOC.Pulse = 16;
sConfigOC.OCPolarity = TIM_OCPOLARITY_HIGH;
sConfigOC.OCFastMode = TIM_OCFAST_DISABLE;
if (HAL_TIM_PWM_ConfigChannel(&htim3, &sConfigOC, TIM_CHANNEL_3) != HAL_OK)
Error_Handler();
__HAL_RCC_GPIOB_CLK_ENABLE();
GPIO_InitStruct.Pin = time_sync_Pin;
GPIO_InitStruct.Alternate = GPIO_AF2_TIM3;
HAL_GPIO_Init(time_sync_GPIO_Port, &GPIO_InitStruct);
int main(void)
HAL_Init();
sysclk_config();
tim_init();
HAL_TIM_PWM_Start(&htim3, TIM_CHANNEL_3);
while (1) {
__disable_irq();
while (1);
- Labels:
STM32F7 Series
STM32H7 Series
TIM
‎2021-05-05 6:07 PM
The H7 has some fractional PLL options, but you don't look to be using those
You could have it print out the SYSCLK, AHB and APB clocks to see if those look right.
MCO can map out a couple of frequencies
All the output from TIM, etc are going to be integer divisions
If you're using a ZI2 version with the V3 ST-LINK, the clock there isn't at all good (not actually 8 MHz), this is a topic of much complaint
‎2021-05-05 5:06 PM
Should be solid.
Remember Period and Prescaler are passed as N-1
Probably want 2048-1 to be On Frequency
‎2021-05-05 5:19 PM
Right, thanks. Good catch! I don't think that accounts for the ~1ms difference I'm seeing. And after fixing this, I'm still getting 992us on time and 125.998 ms off time
‎2021-05-05 6:07 PM
‎2021-05-05 6:24 PM
Short answer, yes, the MCO clock signal is no good - I tried routing the MCO clock signal from a different Discovery board, and I got the expected pwm signal
‎2021-05-05 6:25 PM
Thanks, just verified that it was the clock, and it is the ZI2
‎2021-05-05 6:37 PM
FYI.
You can change the ST-LinkV3 MCO config to generate the clock from F723 HSE.
But, resulted clock freq becomes 8.33MHz (sigh...)
‎2021-05-05 7:32 PM
thanks, that will come in handy!
