Is stm32 micro-controls are capable to calculate Natural Logarithm ?
‎2019-03-08 9:38 PM
I am using Thermistor (NTC Type ) as temperature sensor .
So to calculate the temperature from adc value of STM32 I am using this formula(taken from this site :- https://www.jameco.com/jameco/workshop/techtip/temperature-measurement-ntc-thermistors.html)
1/T = 1/T0 + 1/B * ln( ( adcMax / adcVal ) – 1 )
where :-
T0= 298.15 K
B=3345.80 K
I am using Board 6-Bit adc .
So I want ask that can I use above formula in my program, because I am confuse that controller can calculate "ln (Natural Logarithm) ".
‎2019-03-08 11:21 PM
Interface temperature sensor with any of the adc pin in controller, from pin read the value
sysTemperature = HAL_ADC_GetValue(&hadc1);
sysTemp_inmV = ((float)sysTemperature/4096.0) * 3300; //ref = 3.3
sysTemp_inCel = sysTemp_inmV/10
‎2019-03-09 12:05 AM
Thanks.
Here 12bit adc enable ?
Because 4096 is value 2^12.
‎2019-03-09 3:25 AM
Following functions calculate the natural logarithm (base e):
#include <math.h>
double log(double x);
float logf(float x);
long double logl(long double x);
You may also try to avoid the log calculation by tabulating the function at a suitable step and linearly interpolate between the steps; or by fittingthe function by polynomial.
‎2019-03-10 9:17 PM
OK
‎2019-03-11 12:34 AM
Does this mean that you got the answer you look for? If yes, please click on "Select as Best" for the good answer.
