2020-11-12 1:13 AM
2020-11-12 1:17 AM
Check out the throughput of the interfaces/peripherals you want to use.
That gives you an estimate of the maximal resolution you could record in real time.
Something like 64x48 pixels might work.
2020-11-12 1:27 AM
I will definitely
Thanks a lot Ozone.
2020-11-12 6:23 AM
The upper ceiling on the F407 design is perhaps 18.75 MBps, although the writing to most cards is significantly slower than reading, and some makes/models of cards being particularly slow writers.
The F4 can support the SDXC / Ultra cards although not at the lower signalling voltages.
