Interfacing issue between the STM32F407 controller and SST25Vf016B flash using SPI
KHira.11
I am trying to interface the STM32F407 controller and SST25Vf016B flash using SPI protocol for chibios. I have completed the configuration steps  and I am also able to read the manufacturer ID reg, device ID reg for Flash. But when I try to write data and read it I am getting garbage value. Maybe the data is not written properly. I have also enabled different modes for flash like Write enable and EWSR (Enable Write Status Register). Any ideas to solve the issue.
Kalpesh
waclawek.jan
Before writing, do you erase the respective blocks in FLASH?
After write and erase command, do you read the Status byte and wait until BUSY bit clears?
KHira.11
I am doing chip erase before writing data into it. After write and erase, when I read status byte , I am getting the following data.
_____________________________________________________________
SPI Initialization
Status reg data-> 1C
Status reg data-> 4
Status reg data-> 4
RECEIVED DATA -> 0
Jedec manufacturer id data-> BF
Jedec memory type data-> 25
Jedec device id data-> 41
Status reg data-> 4
RECEIVED DATA -> 0
