2024-10-03 10:11 AM
I am currently working on I2C communication with the STM32G030F6P6 microcontroller and developing a library for slave mode. I encountered an issue where, after the master transmits a command, the slave receives and processes the data, responding accordingly. However, when the command doesn't match the expected input and the master sends a receive request, clock stretching occurs. If anyone has insights on how to handle or resolve this, I would appreciate your suggestions
2024-10-03 02:00 PM
Hello @dhirrajsharma,
Did you check the Errata sheet related to your device?
Try enable the I2C listen mode to handle address match events.
