I receive from pc to micro a uart buffer of ASCII value that rappresent a float number. How can transform this buffer in float number?
MPenn.1
3 REPLIES 3
atod() sscanf() ??​
Guru
There are a lot of hits if you search for this information on Google. Here is one of them:
https://stackoverflow.com/questions/7951019/how-to-convert-string-to-float
Piranha
Chief II
The only safe way with standard library functions is described here:
https://wiki.sei.cmu.edu/confluence/display/c/ERR34-C.+Detect+errors+when+converting+a+string+to+a+number
