I'm using STM32F072, In debug mode, breakpoints not working it shows Breakpoint installation failed: unquote match. What can i do??
aahme.4
5 REPLIES 5
KnarfB
Principal III
What tool?
Both in atolic truestudio and cubemxide.​
KnarfB
Principal III
In STM32CubeIDE is a Breakpoints View. Open it under Window > Show View > Other > Breakpoints. You may disable/delete old breakpoints lurking around here. During debug, you may check the Debugger Console View showing output from gdb. You may also input gdb command here (for experts).
hth
KnarfB
i did but not worked.
Still shows:
breakpoint installation failed: unquote match.
KnarfB
Principal III
"unmachted quote"? Do you have long path names in your project with non-ASCII non-alpha-numeric characters (like space, umlauts,...) in it? Try to avoid that. Move your project to a simple path and maybe import it in a new workspace with a simple path too.
hth
KnarfB
