I have to interface the following in my application: Ethernet – 1 no. SD memory card – 1 no. IOs 24 UART (Serial) – 1 no. LCD – 1 no. And microcontroller selected is STM32F429ZIT6. Please suggest the evaluation board.
C1257
Guru
Probably your only option:
https://www.st.com/en/evaluation-tools/stm32429i-eval.html
Perhaps instead of painting yourself into a corner consider some flexibility in terms of what's on the board, and what you can reasonably add.
LCD has what characteristics? Some other F4 and F7 boards support DSI screens
Other boards might get you most of these things, can the IO be externalized through a concentrator/expander
