I have nucleog0b1re development board. i am not able to debug the repository codes as ide immediately closed as i start debug session. can anyone suggest what could be the problem?
SSING.31
gbm
Principal
Read the messages displayed in the console pane - the problem should be described there.
My STM32 stuff on github - compact USB device stack and more: https://github.com/gbm-ii/gbmUSBdevice
CubeIDE ? Windows ? Did the install go properly? Does it work with any other boards?
Can you access the device via STM32 Cube Programmer ?
Consider Keil? The ST Cortex-M0(+) have a free license
SSING.31
the example codes are running fine and there is no problem in debug but when i write same code and debug the keil ide abruptly close. except examples from cubemx i am not able to run any other code on keil ide
