I can't get my STM32H743VIT6 to receive FDCAN Classic Mode Extended ID messages.
RKjal.1
I used the:
"STM32H743I-EVAL\Examples\FDCAN\FDCAN_Classic_Frame_Networking" example on my board.
I can send and receive Standard ID message to and from my CAN BUS Analyser, but can only send Extended messages. Cannot receive them. I have attached the init code for both Standard and Extended.
TOlli
On line 42 of your code, you define ExtFiltersNbr to 0. Change it to 1 so you can actually assign the extended filter to catch the specific message (you define the filter on line 67)
Best regards,
3 REPLIES 3
SofLit
I tried to create a project in loopback mode based on STM32H743I-EVAL\Examples\FDCAN\FDCAN_Loopback example.
The attached example runs on NUCLEO-H743 board and it sends & receives standard and Extended frames. You can port it to STM32H743I-EVAL board.
Hope this will help you.
STM32
PS:
TOlli
Best regards,
RKjal.1
I haven't had a chance to update but you are exactly right. One of my field engineers from Arrow pointed that out and suddenly everything worked fine.
Thanks for responding.
