I am using stm32f429zi nucleo board, is there any Non-volatile programmable memory ..?
KINGame
3 REPLIES 3
turboscrew
Senior III
The flash, where your program goes.
 And some backup-registers (if you have the backup battery).
I want to save 1500 integer array value and i don't have backup battery for my application.
Is it possible to save these data in flash.(if so can you please share the programming details regarding this)
Thank you
The flash doesn't discriminate between code or data. Should be FLASH examples within the HAL code/example trees of the F4 repository. ​
