I am having an issue with my STM32F446 where I am experiencing a hardfault right after calling HAL_FLASH_Program to write data to internal flash, when I check the CFSR registerI see that the UNDEFINSTR flag is set to high.
‎2023-03-28 5:38 AM
I am using the following code to write data to flash memory:
#include "stm32f4xx_hal.h"
#include "stm32f4xx_hal_flash.h"
#define DATA_SIZE 4
int main(void)
uint32_t data[DATA_SIZE] = {0x12345678, 0x90ABCDEF, 0xDEADBEEF, 0xCAFEBABE};
uint32_t address = 0x08000040; // Starting address of sector 0
HAL_Init();
HAL_FLASH_Unlock(); // Unlock flash
// Erase sector 0
FLASH_Erase_Sector(FLASH_SECTOR_0, FLASH_VOLTAGE_RANGE_3);
// Write data to flash
for (int i = 0; i < DATA_SIZE; i++) {
if (HAL_FLASH_Program(FLASH_TYPEPROGRAM_WORD, address, data[i]) != HAL_OK) {
// Handle write error
address += sizeof(data[i]);
HAL_FLASH_Lock(); // Lock flash
while (1) {
// Main loop
Could you please help me understand why I am experiencing a hardfault and what is causing the
UNDEFINSTR
flag to be set to high in the
CFSR
register?
Thank you in advance for your help.
Best regards,
Flash
STM32F4 Series
‎2023-03-28 6:25 AM
Use FLASH that's not hosting your code.
You might need to make a hole in the F4 memory map to free a smaller block.
You need some bootable code at 0x08000000​
‎2023-03-28 5:53 AM
Hello @MOhamed_Mehery​,
Have you tried the example provided on Cube Firmware? Here is a link STM32CubeF4/Projects/STM32F446ZE-Nucleo/Examples/FLASH/FLASH_EraseProgram at master · STMicroelectronics/STM32CubeF4 (github.com)
If still facing same issue, ensure that the data you are trying to write to flash is properly formatted and aligned.
‎2023-03-28 5:59 AM
Which memory/address do you run this code from? You are erasing beginning of FLASH - do you remap area 0x0000'0000, and/or relocate VTOR appropriately?
‎2023-03-28 6:25 AM
