MMüll.5
I am getting the warning: #174-D expression has no effect.
  • December 10, 2021
  • 3138 views
I am trying to get the bits of an uint8_t into an array. I use two for loops for that and don't know why I get this warning.
This is the code I use:
void System_Info_Get_Jumper_State(I2C_HandleTypeDef* hi2c1, uint8_t* Jumper_State_Array_Address)
		uint8_t Jumper_States[2] = {0x00};
		uint8_t Bit_Mask = 1;
		HAL_I2C_Mem_Read(hi2c1, System_Info_Address, System_Info_Input_Register1_Address, 1, Jumper_States, 2, 1000);
		for(uint8_t Run_Through = 0; Run_Through <= 1; Run_Through ++)
			for(uint8_t Place = 0; Place <= 7; Place++)
				Jumper_State_Array_Address[Place] = Bit_Mask & Jumper_States[Run_Through];
				Bit_Mask << 1;
			Bit_Mask = 1;
 The warning points to line 12 where the bit shft happens.
Best answer by waclawek.jan
> Bit_Mask << 1;
You wanted to write:
Bit_Mask <<= 1;
waclawek.jan
waclawek.janBest answer
> Bit_Mask << 1;
Bit_Mask <<= 1;
MMüll.5
MMüll.5Author
Thank you that solved my problem.
