I am converting a project built on an STM32F072 to an STM32L071. I use a small area of flash memory to store some tables, etc. < 100 bytes. The program using the STM32IDE works fine for the F072, but I get a Hard fault with the L071.
‎2021-03-29 1:14 PM
‎2021-03-29 1:21 PM
Not really much detail to bite on there.
Does the L0 have width and alignment expectations?
Have a Hard Fault Handler that outputs some actionable data, look at the code faulting, look at the registers, and the address that's causing the issue.
‎2021-03-29 11:45 PM
Maybe you use flash as eeprom code in F072, but addressing and size for L071 is other. Too L071 have internal EEPROM then better is use it instead flash writes.
‎2021-03-30 2:48 AM
Lots of info on debugging Hard Faults:
#HardFault​
‎2021-03-30 1:48 PM
Thanks to MM..1, I used Data eeprom and it worked perfectly, Thanks!
‎2021-03-30 3:00 PM
While on STM32F, erased flash is 0xff. it is 0 on STM32L0. That could be a pitfall too.
‎2021-03-31 3:01 AM
