2017-03-01 01:17 PM
Everybody,
How to use USB as Mass Storage Class ?
This question is related with SDIO I had done intiating,
Which configuration file do I need to change ?
I can see drive E on my computer now, but can not read the content yet,
Anyone knows ?
2017-03-02 03:10 PM
This one ?
STM32Cube\Repository\STM32Cube_FW_F1_V1.4.0\Projects\STM3210E_EVAL\Applications\USB_Device\MSC_Standalone
usbd_storage.c, how to relate them ?
2017-03-02 03:11 PM
* @file USB_Device/MSC_Standalone/Src/usbd_storage.c**
* @author MCD Application Team**
* @version V1.4.0**
* @date 29-April-2016**
* @brief Memory management layer**
* @attention**
* h2. <center>© Copyright © 2016 STMicroelectronics
International N.V. **
* All rights reserved.</center>
* Redistribution and use in source and binary forms, with or without **
* modification, are permitted, provided that the following
conditions are met:**
* 1. Redistribution of source code must retain the above copyright
notice, **
* this list of conditions and the following disclaimer.**
* 2. Redistributions in binary form must reproduce the above
copyright notice,**
* this list of conditions and the following disclaimer in the
documentation**
* and/or other materials provided with the distribution.**
* 3. Neither the name of STMicroelectronics nor the names of other **
* contributors to this software may be used to endorse or promote
products **
* derived from this software without specific written permission.**
* 4. This software, including modifications and/or derivative works
of this **
* software, must execute solely and exclusively on
microcontroller or**
* microprocessor devices manufactured by or for STMicroelectronics.**
* 5. Redistribution and use of this software other than as permitted
under **
* this license is void and will automatically terminate your
rights under **
* this license. **
* THIS SOFTWARE IS PROVIDED BY STMICROELECTRONICS AND CONTRIBUTORS
'AS IS' **
* AND ANY EXPRESS, IMPLIED OR STATUTORY WARRANTIES, INCLUDING, BUT
NOT **
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR
A **
* PARTICULAR PURPOSE AND NON-INFRINGEMENT OF THIRD PARTY
INTELLECTUAL PROPERTY**
* RIGHTS ARE DISCLAIMED TO THE FULLEST EXTENT PERMITTED BY LAW. IN
NO EVENT **
* SHALL STMICROELECTRONICS OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT,
INDIRECT,**
* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
(INCLUDING, BUT NOT**
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
USE, DATA, **
* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
THEORY OF **
* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
(INCLUDING **
* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
SOFTWARE,**
* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.**
*/ Includes
2017-03-03 01:45 AM
Function Name : STORAGE_Init_FS
Description :
Input : None.
Output : None.
Return : None.
int8_t STORAGE_Init_FS (uint8_t lun)
/* USER CODE BEGIN 2 */
printf('STORAGE_Init_FS function!\n');
BSP_SD_Init(); <=== Why is it stopped here ?? It's working without
USB.*
return (USBD_OK);
/* USER CODE END 2 */
Function Name : STORAGE_GetCapacity_FS
Description :
Input : None.
Output : None.
Return : None.
int8_t STORAGE_GetCapacity_FS (uint8_t lun, uint32_t *block_num,
uint16_t *block_size)
/* USER CODE BEGIN 3 */
HAL_SD_Get_CardInfo(&hsd, &SDCardInfo);
*block_num = SDCardInfo.CardCapacity / STORAGE_BLK_SIZ;
*block_size = STORAGE_BLK_SIZ;
printf('STORAGE_GetCapacity function!\n');
return (USBD_OK);
/* USER CODE END 3 */
2017-03-03 03:39 AM
{ /* USER CODE BEGIN 2 */ printf('STORAGE_Init_FS function!\n'); MX_SDIO_SD_Init(); <== answer my question, now it's working like a charm //BSP_SD_Init(); return (USBD_OK); /* USER CODE END 2 */ }Still got unexpected error for reading message when I login ???
