2023-05-17 1:13 AM
Could someone plz point me example code on how to use Brown Out Reset or Voltage supervisor to monitor Vdd voltage, if it's less than some value, I can reset mcu.
2023-05-18 12:27 PM
Maybe you are looking for the Programmable Voltage Detector, PVD. That is unavailable in the 'F030; it is available in other 'F0xx.
2023-05-18 12:27 PM
