How to use DMA to change PWM frequency?
‎2021-07-04 12:37 PM
Hi! I know overall idea of DMA and i need to use it but i have no idea how to do it.
I found one post with same question but i didn't found any helpful info for me. I'm not advanced in case of using registers. I used them to directly change CCR and ARR sometimes, so I need a direct answer.
Edit: It is worth mentioning that I use CubeIDE
Thanks for help
‎2021-07-05 11:42 AM
It turned out that i don't need DMA at all. I thought I needed because weird things were happening when i was updating ARR directly with TIMx->ARR = y. It turned out that I was doing that when counter was waaay beyond my y value. I just added line to reset CNT value and everything works like a charm.
‎2021-07-05 1:53 PM
Look at my first reply:
> Make sure ARR preload is switched on.
Read the TIM chapter. ARR preload is switched on by setting TIMx_CR1.ARPE.
- « Previous
- 1
- 2
- Next »
