How to use CMSIS-DSP with STM32G431 in Keil compiler? Getting compiler error
BTrem.1
Senior II
I want to use a CMSIS-DSP FIR function in my code and get a compile error:
compiling phase_det.c...
../Drivers/CMSIS/Include/core_cm4.h(81): error:  #35: #error directive: "Compiler generates FPU instructions for a device without an FPU (check __FPU_PRESENT)"
        #error "Compiler generates FPU instructions for a device without an FPU (check __FPU_PRESENT)"
..\Src\phase_det.c: 0 warnings, 1 error
In Keil I used the 'Manage Runtime Environment ' to add CMSIS-DSP Library. In my source code file I haven't yet added the FIR, but I did add the include "arm_math.h".
What does the above error mean? The STM32G431 does have an FPU as far as I know (Ref Manual). Anyway, I want to use fixed point FIR.
What steps do I need to take to properly install the CMSIS-DSP Library?
Did you post this on the Keil forum 2 months ago?
https://community.arm.com/developer/tools-software/tools/f/keil-forum/48498/how-to-use-cmsis-dsp-library-on-stm32g431--getting-compile-error
EDIT
Ah - the OP here is 2 months old, too: @Igor Cesko​  has just woken it up!
5 REPLIES 5
Igor Cesko
https://community.st.com/s/question/0D53W00000BL3mXSAT/error-compiler-generates-fpu-instructions-for-a-device-without-an-fpu-check-fpupresent
EDIT
Yes that's me. Problem resolved with order of #includes.
Then please update your Keil thread, and mark the solution there.
Also choose 'Best Answer' here:
