How to upload sw to B-L072Z-LRWAN1?
Jeroen deBuffel
Posted on June 09, 2017 at 16:51
I am new to STM32 MCUs and looking for a simple tutorial on how to upload software to this board.
Of course I checked google etc beforehand but have not found a simple tutorial on how to get the B-L072Z-LRWAN1 started (normally I am using platformIO but open for other suggestions to easily get STM discovery board up and running).
Any help or guidance would be appreciated :)
7 REPLIES 7
Imen.D
Posted on June 09, 2017 at 16:59
Hi
debuffel
You have in the
/external-link.jspa?url=http%3A%2F%2Fwww.st.com%2Fcontent%2Fst_com%2Fen%2Fproducts%2Fevaluation-tools%2Fproduct-evaluation-tools%2Fmcu-eval-tools%2Fstm32-mcu-eval-tools%2Fstm32-mcu-discovery-kits%2Fb-l072z-lrwan1.html
page User manuals and a link to the
http://www.st.com/content/st_com/en/products/embedded-software/mcus-embedded-software/stm32-embedded-software/stm32cube-expansion-software/i-cube-lrwan.html
software expansion for STM32Cube with UM2073 user manual.
Hope this helps you.
Imen
Imen
Posted on June 09, 2017 at 17:12
The ST-LINK Utilities can download .HEX or .BIN files.
Integrated directly into tools like Keil, basically open the project, select the target, build, download, done.
Posted on June 09, 2017 at 17:19
Thanks Imen. I already downloaded these sw packages // however once downloaded there is not a document which explains how to use files (probably for the novice it goes without saying ... not for me (yet)). That's why I was looking for simple tutorial movie or doc.
Posted on June 09, 2017 at 17:20
Thanks. Maybe I need to use Keil / and what is the function of icube sw in that case?
Posted on June 09, 2017 at 21:28
Keil looks ok - but to build sw for the STM32L072 Discovery Kit it seems that I need the another (commercial) version of Keil.
linking...
.\mlm32l07x01\NUCLEO_CUBE_LORA.axf: error: L6050U: The code size of this image (40116 bytes) exceeds the maximum allowed for this version of the linker.
Finished: 0 information, 0 warning, 0 error and 1 fatal error messages.
'.\mlm32l07x01\NUCLEO_CUBE_LORA.axf' - 1 Error(s), 0 Warning(s).
Target not created.
Build Time Elapsed:  00:00:06
I thought discovery kits should be easy ???? ;)
Posted on June 10, 2017 at 18:42
http://www2.keil.com/stmicroelectronics-stm32/mdk
Posted on June 12, 2017 at 08:08
Thanks a lot for the tips Clive. Got the disco working!
