VL6180X use on a X-NUCLEO-53L0A1 (STM32)
Marcel Portmann
Posted on June 12, 2017 at 11:06
Hi
I use X-NUCLEO-53L0A1 (STM32) and its API (
http://www.st.com/content/st_com/en/products/embedded-software/proximity-sensors-software/stsw-img005.html
) to work with VL53L0X (and the satellite-boards) and
it works pretty good. (compiling and for me important: debugging)
Now I try to use VL6180X as one satellite, to see differences in range, precision etc. on serial-output at the �same� time.
Do I have to write the VL61-API-Part (
) into existing API for initialising and read-out of the sensors or
is there a sample-code in which both sensors a �married�. (X-NUCLEO-6180XA1 can be also an alternative)
Thank you for the feedback.
Kind regards
Marcel
#vl6180x-on-x-nucleo-53l0a1
0 REPLIES 0
