How to set an alarm in RTC to wakeup the MCU from the stop mode by using RTC alarm for every 5 minutes in STM32L4Rxx MCU?
2021-11-25 12:00 AM
Actually the RTC alarm I've set isn't coming out exactly. It triggers only once, after that it'll keep getting triggered for every one minute. How to do it for every X minutes?
- Labels:
RTC
STM32L4 series
2021-11-25 11:58 PM
Well, @Shilpashree Madhu, you already took your code from there, right?
But let's analyze the code again and your modification:
- we assume you are using LSE with a crystal of 32.768kHz
- predivider:
- line 188: the asynchronous predivider is set to 127+1 = 2^7
- line 189: the synchronous predivider is set to 255+1 = 2^8
- together they give a predivider of 2^7 * 2^8 = 2^15 = 32768, which creates an RTC input clock (ck_spre) of 2^15Hz / 2^15 = 1Hz
- RTC:
- line 104: RTC gets its clock from RTC_WAKEUPCLOCK_CK_SPRE_17BITS, which adds 0x10000 = 65536 to the register WUT (see reference [1] at the bottom)
- line 104: WUT is set to 0x3C08D = 245901
- so it'll take 245901 + 65536 +1 = 311438 clock cycles of ck_spre to raise a WakeUp interrupt
- periodic time for the interrupt will be WUT(total) / ck_spre = 311438 / 1Hz = 311438s
It means you will see an interrupt, i.e. a wakeup, after 3 days 14 hours 30 minutes, 38 secs. :D
Please change:
- RTC_WAKEUPCLOCK_CK_SPRE_17BITS to RTC_WAKEUPCLOCK_CK_SPRE_16BITS
- 0x3C08D to 119 (or 0x77, if you prefer)
then you should get a 1 second flash every 2 minutes.
[1] see RM0432, section 46.6.3 RTC control register RTC_CR, bits WUCKSEL:
WUT = Wakeup unit counter value. WUT = (0x0000 to 0xFFFF) + 0x10000 added when WUCKSEL[2:1 = 11].
--> WUCKSEL[2:1 = 11] = RTC_WAKEUPCLOCK_CK_SPRE_17BITS
Does it answer your question?
/Peter
2021-11-25 3:59 AM
Welcome, @Shilpashree Madhu, to the community!
Unfortunately, you did not show us your settings for the RTC.
Anyway, you either:
- have to set the alarm to the next time each time you wake up (depending on the time difference, possibly a quite complex calculation, especially at the end of the day)
- or (probably easier) use the periodic wake-up (RM0432, section 46.3.6).
/Peter
2021-11-25 4:51 AM
Thanks @Peter BENSCH , much appriciated.
As you said, I checked it using wakeup timer. But unfortunately it's still the same. I'm not able to get output for 2 minutes.
Should I change anything in this?
/* USER CODE BEGIN Header */
* @file : main.c
* @brief : Main program body
* @attention
* <h2><center>© Copyright (c) 2021 STMicroelectronics.
* All rights reserved.</center></h2>
* This software component is licensed by ST under BSD 3-Clause license,
* the "License"; You may not use this file except in compliance with the
* License. You may obtain a copy of the License at:
* opensource.org/licenses/BSD-3-Clause
/* USER CODE END Header */
#include "main.h"
/* USER CODE END Includes */
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* USER CODE BEGIN PM */
/* USER CODE END PM */
RTC_HandleTypeDef hrtc;
/* USER CODE BEGIN PV */
/* USER CODE END PV */
static void MX_RTC_Init(void);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
* @brief The application entry point.
* @retval int
int main(void)
/* USER CODE BEGIN 1 */
/* USER CODE END 1 */
HAL_Init();
/* USER CODE BEGIN Init */
/* USER CODE END Init */
SystemClock_Config();
/* USER CODE BEGIN SysInit */
/* USER CODE END SysInit */
MX_GPIO_Init();
MX_RTC_Init();
/* USER CODE BEGIN 2 */
/* USER CODE END 2 */
/* Infinite loop */
/* USER CODE BEGIN WHILE */
while (1)
/* USER CODE END WHILE */
HAL_GPIO_WritePin(GPIOB,GPIO_PIN_7, GPIO_PIN_SET);
HAL_Delay(1000);
HAL_GPIO_WritePin(GPIOB,GPIO_PIN_7, GPIO_PIN_RESET);
HAL_SuspendTick();
HAL_RTCEx_SetWakeUpTimer_IT(&hrtc,0x3C08D, RTC_WAKEUPCLOCK_CK_SPRE_17BITS);
/* Enter STOP 2 mode */
HAL_PWREx_EnterSTOP2Mode(PWR_STOPENTRY_WFI);
HAL_RTCEx_DeactivateWakeUpTimer(&hrtc);
HAL_ResumeTick();
/* USER CODE BEGIN 3 */
/* USER CODE END 3 */
* @retval None
void SystemClock_Config(void)
RCC_PeriphCLKInitTypeDef PeriphClkInit = {0};
if (HAL_PWREx_ControlVoltageScaling(PWR_REGULATOR_VOLTAGE_SCALE1) != HAL_OK)
Error_Handler();
/** Configure LSE Drive Capability
HAL_PWR_EnableBkUpAccess();
__HAL_RCC_LSEDRIVE_CONFIG(RCC_LSEDRIVE_LOW);
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_LSE|RCC_OSCILLATORTYPE_MSI;
RCC_OscInitStruct.LSEState = RCC_LSE_ON;
RCC_OscInitStruct.MSIState = RCC_MSI_ON;
RCC_OscInitStruct.MSICalibrationValue = 0;
RCC_OscInitStruct.MSIClockRange = RCC_MSIRANGE_8;
RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE;
Error_Handler();
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_MSI;
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK)
Error_Handler();
PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_RTC;
PeriphClkInit.RTCClockSelection = RCC_RTCCLKSOURCE_LSE;
if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK)
Error_Handler();
* @brief RTC Initialization Function
* @param None
* @retval None
/* USER CODE BEGIN RTC_Init 0 */
/* USER CODE END RTC_Init 0 */
/* USER CODE BEGIN RTC_Init 1 */
/* USER CODE END RTC_Init 1 */
/** Initialize RTC Only
hrtc.Instance = RTC;
hrtc.Init.HourFormat = RTC_HOURFORMAT_24;
hrtc.Init.AsynchPrediv = 127;
hrtc.Init.SynchPrediv = 255;
hrtc.Init.OutPut = RTC_OUTPUT_DISABLE;
hrtc.Init.OutPutRemap = RTC_OUTPUT_REMAP_NONE;
hrtc.Init.OutPutPolarity = RTC_OUTPUT_POLARITY_HIGH;
hrtc.Init.OutPutType = RTC_OUTPUT_TYPE_OPENDRAIN;
if (HAL_RTC_Init(&hrtc) != HAL_OK)
Error_Handler();
/** Enable the WakeUp
// if (HAL_RTCEx_SetWakeUpTimer_IT(&hrtc, 0x500B, RTC_WAKEUPCLOCK_RTCCLK_DIV16) != HAL_OK)
// Error_Handler();
/* USER CODE BEGIN RTC_Init 2 */
/* USER CODE END RTC_Init 2 */
* @param None
* @retval None
/* GPIO Ports Clock Enable */
__HAL_RCC_GPIOC_CLK_ENABLE();
__HAL_RCC_GPIOB_CLK_ENABLE();
/*Configure GPIO pin Output Level */
HAL_GPIO_WritePin(GPIOB, GPIO_PIN_7, GPIO_PIN_RESET);
/*Configure GPIO pin : PB7 */
GPIO_InitStruct.Pin = GPIO_PIN_7;
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
* @brief This function is executed in case of error occurrence.
* @retval None
void Error_Handler(void)
__disable_irq();
while (1)
#ifdef USE_FULL_ASSERT
* @brief Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* @param file: pointer to the source file name
* @param line: assert_param error line source number
* @retval None
void assert_failed(uint8_t *file, uint32_t line)
/* USER CODE BEGIN 6 */
/* User can add his own implementation to report the file name and line number,
ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
2021-11-25 10:21 PM
Hello @Shilpashree Madhu ,
I advise you this FAQ: How to configure the RTC to wake up the STM32 periodically from Low Power modes, this will help you to configure the RTC peripheral of the STM32 to wake up the STM32 periodically from STOP2 mode.
I hope this helps !
When your question is answered, please close this topic by choosing Select as Best.
Imen
Imen
2021-11-25 11:58 PM
- predivider:
- RTC:
Please change:
/Peter
2021-11-26 12:04 AM
Thanks for your response @Imen DAHMEN , it was very informatiive & got the solution.
2021-11-26 12:05 AM
Thank you very much @Peter BENSCH
Your explanation was very informative & conceptual & got the solution.
