How to reduce the I2C speed ?
I am working on a STM32F746G-DISCO with I2C got on Arduino style board.
I would like to reduce the I2C speed because sometime this lock my app with some external DAC chip.
At this time I am using:
CAMERA_IO_Init();
BSP_TS_Init(480, 272);
and these function to read and write the reg on external DAC chip
CAMERA_IO_Write(0x90, 8, 0b10011001);
reg11 = CAMERA_IO_Read(0x90, 11);
4 REPLIES 4
Guru
The clock speed is set within the I2C initialization function. The relevant register is I2C->TIMINGR.
Probably I have found the point where to set it
Could you confirm this ?
static void I2Cx_Init(I2C_HandleTypeDef *i2c_handler)
  if(HAL_I2C_GetState(i2c_handler) == HAL_I2C_STATE_RESET)
    if (i2c_handler == (I2C_HandleTypeDef*)(&hI2cAudioHandler))
      /* Audio and LCD I2C configuration */
      i2c_handler->Instance = DISCOVERY_AUDIO_I2Cx;
      //i2c_handler->Instance = DISCOVERY_EXT_I2Cx;
    else
      /* External, camera and Arduino connector  I2C configuration */
#define DISCOVERY_I2Cx_TIMING_ORIG                      ((uint32_t)0x40912732)
#define DISCOVERY_I2Cx_TIMING_NEW                      ((uint32_t)0x10911823)
#define DISCOVERY_I2Cx_TIMING_NEW1                      ((uint32_t)0x00611116)
    i2c_handler->Init.Timing           = DISCOVERY_I2Cx_TIMING_NEW1;
    i2c_handler->Init.OwnAddress1      = 0;
    i2c_handler->Init.AddressingMode   = I2C_ADDRESSINGMODE_7BIT;
    i2c_handler->Init.DualAddressMode  = I2C_DUALADDRESS_DISABLE;
    i2c_handler->Init.OwnAddress2      = 0;
    i2c_handler->Init.GeneralCallMode  = I2C_GENERALCALL_DISABLE;
    i2c_handler->Init.NoStretchMode    = I2C_NOSTRETCH_DISABLE;
    /* Init the I2C */
    I2Cx_MspInit(i2c_handler);
    HAL_I2C_Init(i2c_handler);
Why I have no I2C bus problems using the EXT/RF E2P connector (pin EXT_SDA/EXT_SCL) instead of CN7 connector (pin SDA/SCL) ?
Is this the point to modify the freq ?
//#define DISCOVERY_I2Cx_TIMING_ORIG                     ((uint32_t)0x40912732)
//#define DISCOVERY_I2Cx_TIMING_NEW                     ((uint32_t)0x10911823)
//#define DISCOVERY_I2Cx_TIMING_NEW1                     ((uint32_t)0x00611116)
   i2c_handler->Init.Timing          = DISCOVERY_I2Cx_TIMING;
Guru
Here's what the code says about that parameter:
  uint32_t Timing;              /*!< Specifies the I2C_TIMINGR_register value.
                                  This parameter calculated by referring to I2C initialization
                                         section in Reference manual */
