How to printf in Keil ( Nucleo L073RZ)
waiyang93
Posted on May 26, 2016 at 18:16
Currently I am using ST nucleo L073RZ with Keil testing with stm32
cubeL0 example code. Is there any way to do a printf in Keil say print out the value in the debug printf window.
#printf #keil #nucleo #stm32l0
6 REPLIES 6
Posted on May 26, 2016 at 19:44
The Cortex-M0 doesn't not provide for the SWV (Serial Wire Viewer) model used on the M3/M4 designs.
You would need to use the serial port (VCP of ST-LINK) and add Retargeting code for that into your Keil project, and then use a terminal app like RealTerm, ClearTerm or TeraTerm, etc to interact with the board.
http://www.keil.com/support/man/docs/gsac/gsac_retargetcortex.htm
waiyang93
Posted on May 27, 2016 at 04:25
Hi clive 1 thanks for the reply , I added the retarget.c file into my project folder . However, how do I make use of the fputc to print out the value? For example I need to print out this buffer value which send out by Tx
/* Buffer used for transmission */
uint8_t aTxBuffer[] = '' ****UART_TwoBoards_ComIT**** ****UART_TwoBoards_ComIT****  ****UART_TwoBoards_ComIT**** '';
Posted on May 28, 2016 at 18:39
puts(aTxBuffer); //?? via STDIO
outstring(aTxBuffer); // simple character at a time string processing
void outstring(char *s)
while(*s)
while(!(USART1->ISR & USART_ISR_TXE));
USART1->TDR = *s++;
void outchar(char c)
USART1->TDR = c;
int SendChar(int c)
USART1->TDR = c;
return(c);
#include <
rt_misc.h
#pragma import(__use_no_semihosting_swi)
struct __FILE { int handle; /* Add whatever you need here */ };
FILE __stdout;
FILE __stdin;
int fputc(int ch, FILE *f) { return (SendChar(ch)); }
int ferror(FILE *f)
/* Your implementation of ferror */
return EOF;
void _ttywrch(int ch) { SendChar(ch); }
void _sys_exit(int return_code)
label: goto label; /* endless loop */
waiyang93
Posted on May 30, 2016 at 08:37
I have edited the retarget.c however all the usart terms are underline. Do I need to define something or include some library?
//code///////
 * Name:    Retarget.c
 * Purpose: 'Retarget' layer for target-dependent low level functions
 * Note(s):
 * This file is part of the µVision/ARM development tools.
 * This software may only be used under the terms of a valid, current,
 * end user licence from KEIL for a compatible version of KEIL software
 * development tools. Nothing else gives you the right to use this software.
 * This software is supplied ''AS IS'' without warranties of any kind.
 * Copyright (c) 2009 Keil - An ARM Company. All rights reserved.
#include <stdio.h>
#include <rt_misc.h>
extern int sendchar (int c);
extern int getkey   (void);
FILE __stdout;
FILE __stdin;
int fputc(int c, FILE *f) {
  return (sendchar(c));
int fgetc(FILE *f) {
  return (getkey());
int ferror(FILE *f) {
  return EOF;
void _ttywrch(int c) {
  sendchar(c);
void _sys_exit(int return_code) {
   while(*s)
    USART1->TDR = *s++;
  USART1->TDR = c;
int SendChar(int c)
  USART1->TDR = c;
  return(c);
Posted on January 27, 2018 at 03:20
The Cortex-M0 can use the 'Event Recorder'
http://www.keil.com/pack/doc/compiler/RetargetIO/html/_retarget__examples_er.html
