How to obtain 1.25 MIPS
‎2018-02-16 5:52 AM
Hello
With my previous experience with Atmel 8bit MCUs, which have 1MIPS/MHz perfomance, I had exactly 1 executed instruction per systick.
Now I'm using STM32F103. I noted from datasheet that its perfomance is 1.25 DMIPS/MHz. So I wrote small assembler program, in short:
LDR param0, [R6] ; param0 receiver, R6 contains address in periph bit-bang
STR param0, [R7], #4 ; R7 contains address in SRAM bit-bangB Loop ;There's no prescalers neither for AHB not for APB1/2. I downloaded this small code in embedded SRAM, set flash latency to 0, disabled flash prefetch buffer, off all interrupts and DMA.
Then I measured how fast executes this code from SRAM. The result is that one command takes 4 systicks (branch takes 8), and actual perfomance is 0.25 MIPS/MHz.
What I did wrong? Or misunderstood?
‎2018-02-16 6:04 AM
You mean bit-band?
Bit-banding is internally a read-modify-write.
Accessing peripherals is going through the AHB/APB bus, which may add further few clocks of latency.
These are NOT microcontrollers as you are used to from the 8-bitters, where all components are clocked tightly with the processor core.
These are SoC, a system like you would in past build on a board from a processor, memories and bunch of peripheral chips; with a timing arbitrator, heavily relying on combining waitstates of all related parties.
‎2018-02-16 6:19 AM
1.25 DMIPS/MHz'
DMIPS != MIPS.
‎2018-02-16 7:21 AM
I am afraid you misunderstood what a DMIPS is (datasheet mentions Dhrystone 2.1). See there:
‎2018-02-16 7:37 AM
Thats interesting where the border line goes between a MCU and a SoC. Imagine its quite floating since a ST32Fxx is a lot simpler (yet cumbersome) then a Sitara AM3358 (example).
‎2018-02-16 7:38 AM
Thanks for answer. I was pretty sure, that I can not get real 1 MIPS.
But answer still opened for me: what is 1.5 DMIPS? What commands should I make core to execute to reach this perfomance?
And how about branch command? There no conditions and no periph accessing, but still takes about 8 ticks
‎2018-02-16 7:52 AM
Branching are defined with costs of some sort on most micros. Why not try benchmarking on a CCM RAM device,
(F303/F407 etc) RAM that sits on CPU bus directly?
‎2018-02-16 7:57 AM
I do not have any of them. And I do not want to do some benchmarks. I made some device with F103. I thought it can solve a task gived to it, but it seems to slow, and I wandered why. The freq is very high (in comparsion with my last 8bit MCUs).
‎2018-02-16 7:58 AM
I agree.
But
now I really confused. How can be DMIPS > MIPS ? I thougt that DMIPS is some kind of average speed.
‎2018-02-16 8:05 AM
Mikas,
As with most terms around in electronics.
The marketing wants their share, too, so they will loudly disagree with my 'definition', as they want to replace the 8-bitters by 32-bitters at all costs (pun intended).
Roman,
How do you know?
