How to initialize a constant inside the DATAEEPROM of a STM32L053 MCU.
CZamb.2
I'm trying to use this lines of code:
#define DATA_EEPROM_BASE_ADDRESS = 0x08080000;
const calibration_param_t parameters __attribute__((at(DATA_EEPROM_BASE_ADDRESS)));
but if I check in debug, the constant structure parameters is allocated inside the code flash (at the address 0x0800d4f8).
Should I add something to the linker script for example? in my .ld file I have this memory definition:
MEMORY
 RAM  (xrw)  : ORIGIN = 0x20000000,  LENGTH = 8K
 FLASH  (rx)  : ORIGIN = 0x08000000,  LENGTH = 64K
Flash ends at 0x08010000, that is lower than 0x08080000..could that be the problem? if yes, how to modify the script?
thank you
Cristiano
CZamb.2
I have found a solution by myself. I have modified the .ld file in order to add a section:
/* Memories definition */
MEMORY
 EEPROM (rx)  : ORIGIN = 0x08080000,  LENGTH = 2K
/* Sections */
SECTIONS
/* User_heap_stack section, used to check that there is enough "RAM" Ram type memory left */
 ._user_heap_stack :
  . = ALIGN(8);
  PROVIDE ( end = . );
  PROVIDE ( _end = . );
  . = . + _Min_Heap_Size;
  . = . + _Min_Stack_Size;
  . = ALIGN(8);
 } >RAM
/* Added this section */
 .dataeeprom :
  . = ALIGN(4);
  _sdataeeprom = .;    /* create a global symbol at data start */
  *(.dataeeprom)      /* .data sections */
  *(.dataeeprom*)     /* .data* sections */
*(.eeprom)      /* .data sections */
  *(.eeprom*)     /* .data* sections */
  . = ALIGN(4);
  _edataeeprom = .;    /* define a global symbol at data end */
 } >EEPROM AT> FLASH
and defining the constant this way:
const calibration_param_t calibration_parameters __attribute__((section(".eeprom"))) = {
it works...any idea if this is actually ok? I can't understand why I had to add two sections (dataeeprom and eeprom), as using section(".dataeeprom") was not working.
thank you
C.
