How to enable generation of HAL_NAND_MspInit()
Peter Ivanov
Posted on September 17, 2017 at 17:46
The HAL_NAND_MspInit() is not generated in the stm32f4xx_hal_msp.c when the attached .ioc is used. Therefore the NAND pins are not driven by the MCU and NAND driver is not working at all. How can I enable generation of GPIO initialization code? Or is it a bug?
Thanks,
Peter
3 REPLIES 3
Imen.D
Posted on September 18, 2017 at 18:11
Hello
Ivanov.Peter
After check in your project, I found the generation of GPIO initialized in
stm32f4xx_hal_msp.c and called by HAL_FSMC_MspInit () function
Kind Regards
Imen
Imen
Posted on September 18, 2017 at 19:02
Hi Imen,
Interesting. Thanks for checking. Maybe it is because I'm running CubeMX on Arch Linux?
I've tried this .ioc on a Windows machine and the FSMC initialization code is generated.
Best regards,
Peter
Posted on September 18, 2017 at 19:09
Hi
Ivanov.Peter
I raised your feedback internally to CubeMx team for more check this case, specially on Arch Linux.
Best Regards
Imen
Imen
