How to detect STM32H573I-DK link status by HAL_ETH_ReadPHYRegister?
EyckHuang
Hi supporter,
I'm developing STM32H573I-DK and trying HAL_ETH_ReadPHYRegister to check link status. But this API seems be changed.
Previous prototype is:
HAL_StatusTypeDef HAL_ETH_ReadPHYRegister(ETH_HandleTypeDef *heth, uint16_t PHYReg, uint32_t *RegValue)
But now is:
HAL_StatusTypeDef HAL_ETH_ReadPHYRegister(ETH_HandleTypeDef *heth, uint32_t PHYAddr, uint32_t PHYReg,uint32_t *pRegValue)
I have no idea what PHYAddr is. And PHY_BSR is also not defined in STM32H5. So, I don't know how to fill PHYReg
Is there any example?
I've referenced to GitHub - STMicroelectronics/STM32CubeH5.
But there are no examples about this API. Thanks for your help.
EyckHuang
Hi all,
I found that the Ethernet chip on STM32H573I-DK is LAN8742A. So, I referenced document and understood the registers map.
HAL_ETH_ReadPHYRegister(&heth, 0, 1, &tempReg)
where 1 is Basic Status Register and Bit 3 is Link Status.
But I don't know why PHYAddr is 0.
Hope this can help others.
EyckHuang
Hi all,
Pavel A.
Evangelist III
IIRC the "PHY address" is documented in the PHY chip datasheet. Otherwise you can scan all 32 addresses and find who responds.
