How to debugging & programming stm32 using ESP8266 Wifi?
parth kothiya
I want to programming & debugging STM32 ​F0 , F1, F4 series MCU wirelessly using ESP8266 wifi module.
MCU connected to esp8266 wifi module through internet connection using ​UART bootloader.
For debugging ​connect using remote GDB server IP & Port no.
How can doing this thing using ESP8266 wifi module ? any example​ or sample code ?
Guru
You can't debug code by interfacing with the UART bootloader. Its functions are very limited. You will need to connect with SWD (or JTAG) for debugging.
Ok
how can I make wireless SWD debugger?
