How to connect WIFI by ESP-01? (STM32H747I-DISCO)
‎2023-05-13 5:51 AM - edited ‎2023-11-20 5:33 AM
ESP-01 is supported on fanout expansion board, how to connect WIFI and send message in local area network? Is there any example?
STM32H7 Series
Wifi
‎2023-05-13 9:06 AM
question is:
what you wanna do then ?
send message should work easy:
https://www.instructables.com/Getting-Started-With-the-ESP8266-ESP-01/
‎2023-05-13 9:23 AM
Thanks!! I want to add this in my ai-vision project.
It do image classification task now, and I want to add sending result through WIFI.(PC or mobile phone, only need text can be sent)
I met some problem:
The AT command seems to need ESP01 module connected to PC directly, but I don't have connector. Can I put AT command in my AI vision project and let my stm32 board control the module?
And what's the specific code? I plug it at expansion board CN4.
‎2023-05-13 10:00 AM - edited ‎2023-11-20 5:33 AM
no PC - just serial connection. read the manual, whats serial connected from H747 to CN4 . should be a usart or uart.
then send serial commands...thats it.
commands:
https://pridopia.co.uk/opencart/pi-doc/ESP8266ATCommandsSet.pdf
you can look at arduino examples, how to do...if you have no own ideas.
https://wolles-elektronikkiste.de/esp8266-esp-01-modul
‎2023-07-04 5:09 AM
has finished this parte finally?
