How should I use Makefile in stm32cubeMX?
2017-06-04 1:46 AM
I generated a
https://community.st.com/tags♯/?tags=makefile
project with STM32cubeMX(4.21.0).But Makefile can't work well.It looks like this:
F:\stm32\project\cubemx\freeRTOS>make
The system cannot find the specified path.
/arm-none-eabi-gcc -c -mcpu=cortex-m3 -mthumb -DUSE_HAL_DRIVER -DSTM32F103xB -IInc -IDrivers/STM32F1xx_HAL_Driver/Inc -IDrivers/STM32F1xx_HAL_Driver/Inc/Legacy -IMiddlewares/Third_Party/FreeRTOS/Source/portable/GCC/ARM_CM3 -IDrivers/CMSIS/Device/ST/STM32F1xx/Include -IMiddlewares/Third_Party/FreeRTOS/Source/include -IMiddlewares/Third_Party/FreeRTOS/Source/CMSIS_RTOS -IDrivers/CMSIS/Include -Og -Wall -fdata-sections -ffunction-sections -g -gdwarf-2 -MMD -MP -MF'build/tasks.d' -MT'build/tasks.d' -Wa,-a,-ad,-alms=build/tasks.lst Middlewares/Third_Party/FreeRTOS/Source/tasks.c -o build/tasks.o'/arm-none-eabi-gcc' is not an internal or external command, nor is it a program to runOr batch files
Makefile:186: recipe for target 'build/tasks.o' failedmake: *** [build/tasks.o] Error 1Then I checked the Makefile and I find:
♯ binaries
BINPATH
PREFIX
= arm-none-eabi-
CC
BINPATH
PREFIX
gcc
AS
BINPATH
PREFIX
gcc -x assembler-with-cpp
CP
BINPATH
PREFIX
objcopy
AR
BINPATH
PREFIX
ar
SZ
BINPATH
PREFIX
size
HEX
CP
-O ihex
BIN
CP
-O binary -S
I did't set $(BINPATH) but It will add a '/' before $(PREFIX).
BINPATH
PREFIX
gcc
Well,I delated the '/' .The Makefile worked normally.
How should I use makefile in stm32cubeMX?
What's your good idea?
Thanks.
#makefile- Mark as New
2017-08-03 12:14 AM
The Makefile is not in 100% shape, so as you suggested, you need to delete the slash or call makefile with an input argument like this:
make BINPATH=/usr/bin all
Best idea is to remove also the $(BINPATH)/ part... in case you don't want to call a specific arm-none-eabi-gcc binary.
Have a nice day,
Renegade
PS: Be aware, the Makefile is not able to rebuild your source code in case of a header file update! This applies to CubeMX version 4.22.0 and below. So don't be surprised...
