How change the PWM polarity of CH2N during runtime ?
‎2022-05-26 10:59 PM
I have set Timer 8 to PWM Generation CH2 CH2N. Based on the value read by the ADC, I want to change the polarity of both CH2 and CH2N. I have found that using
__HAL_TIM_SET_CAPTUREPOLARITY
, I could change the polarity of CH2 but the polarity of CH1N remains the same as shown in the image. So how could I change the polarity of both CH2 CH2N ?
‎2022-05-26 11:46 PM
__HAL_TIM_SET_CAPTUREPOLARITY is for input capture, but not for output compare which does the PWM output here. You may switch from PWM mode 1 to PWM mode 2.
hth
KnarfB
‎2022-05-27 12:03 AM
Which HAL function will do that during runtime ?
‎2022-05-27 7:45 AM
It's the same bit, TIMx_CCER.CCxP, even if maybe Cube/HAL has different incantations for it.
The CCxN channel's polarity is similarly controlled by TIMx_CCER.CCxNP. You can try to find some Cube/HAL macro for that if you want, Cube is open source.
Output Compare mode is determined by TIMx_CCMRx.OCxM field, simply change that field for different mode.
Read the TIM chapter in RM.
‎2022-05-29 12:25 AM
How do I write the code for it? I am new to programming this type of board. I have only experience in programming Arduino
‎2022-05-29 3:26 AM
TIM8->CCER |= TIM_CCER_CC2NE [EDIT] see post below [/EDIT]
I started to write you a longer answer, but then it turned into this.
‎2022-05-29 4:28 AM
This doesn't seem to work. The PWM isn't getting inverted
‎2022-05-29 4:44 AM
Ufff.... sorry.... CCxNE is the Enable bit for the TIMx_CHxN channel. Polarity is swapped using the CCxNP bit:
TIM8->CCER |= TIM_CCER_CC2NP;
‎2022-05-29 5:33 AM
PWM channel of CH2N got inverted, but it didn't work for CH2. Also, I need toggle between non-inverted and inverted PWM based on the value read from the ADC. How can i do that ?
I don't know if the code given below is the correct way to toggle between PWM mode. But it is definitely working.
void HAL_ADC_ConvCpltCallback(ADC_HandleTypeDef* hadc)
value = HAL_ADC_GetValue(&hadc1);
voltage = ReadDCVoltage25(value);
if(voltage>50){
__HAL_TIM_SET_CAPTUREPOLARITY(&htim1,TIM_CHANNEL_2,TIM_INPUTCHANNELPOLARITY_FALLING);
TIM1->CCER |= TIM_CCER_CC2NP ;
else if(voltage<50){
__HAL_TIM_SET_CAPTUREPOLARITY(&htim1,TIM_CHANNEL_2,TIM_INPUTCHANNELPOLARITY_RISING);
‎2022-05-29 6:14 AM
As I said like 3 posts ago, it's CCxP for the TIMx_CHx and CCxNP for TIMx_CHxN.
TIM8->CCER |= TIM_CCER_CC2P;
Have you read the TIM chapter in RM? And within it, the CCER register description?
Have you experimented with the TIM registers in the debugger?
