2021-02-06 01:37 AM
How can I set in Keil MDK, used to stored some parameters such as soft version,manufacture date and so on at a block of(such as a page) STM32G4‘s Flash memory, thanks.
2021-02-06 04:27 AM
Define a section in the scatter file and direct data into it.
Consider using a structure
2021-02-06 04:27 AM
2021-02-18 06:29 PM
thank you,but could you please give a example?
