how can i make the ports( com3 or 4 or 7) option available in flash loader demonstrator application
Apill
Senior
I am trying to understand build boot loader with flasher loader demonstrator application. I came across this problem i.e., I could not able to select port in that application. I am using windows 10,
2 REPLIES 2
Imen.D
Check the connexion with your cable or change it.
Otherwhise, try to use STM32CubeProgrammer tool  for programming STM32 products..
Best Regards,
Imen
Imen
There isn't a standard method to query available ports as I recall, one can enumerate some registry values. Perhaps Win10 altered things or there is something different about theses ports.
Try using STM32 Cube Programmer in UART mode​
