2019-04-23 09:31 PM
I have followed this procedure to build .bin file after following it from a forum : "Build settings -> C/C++ Build -> Settings -> Tool Settings -> Other -> Output format > Binary format" and it generates .binary file not .bin. Also, someone said on a forum that changing .binary to .bin can help but it didn't work. Kindly suggest a way.
Thanks in advance
Siddharth Soni
2019-04-23 09:53 PM
go to your project property --> other -->op format
2019-04-23 10:12 PM
Parth kindly read the question once more. I have already followed this procedure and after selecting binary from Format menu, it is generating .binary file. I want .bin file to proceed and changing the name from .binary to .bin doesn't work.
Kindly help
Siddharth
