2019-06-10 01:42 AM
2019-06-10 04:20 AM
On ST's web, in the product's folder, under Resources, go down to Technical Notes & Articles and select the one you want.
2019-06-10 06:16 AM
Thank you for your answer Jan, the problem is the TN1206 that I've found there describes the packaging from LQFP7x7 to LQFP20x20, but not the LQFP24x24 which is the STM32F207ICT6. Where can I find the right note ?
Claude
2019-06-10 06:46 AM
Whoops, sorry, I did not check your particular model.
Are you sure it comes in tape and reel? The product folder, in the Sample & Buy
table at bottom, contains only Tray.
2019-06-10 07:29 AM
I will check that, thank you for your help Jan, have a nice evening.
Claude
