hex file convert ?
A.Caliskan
Hello
I have hex file.how can i return main code from hex file only
You can't go from a HEX file to the original source code. It is a one way conversion.
3 REPLIES 3
Paul1
Lead
Please clarify exactly what you mean? What is the purpose?
You'd start by disassembling, recognizing the CRT, SPL or HAL libraries.
Probably wouldn't get C source out, but you could get assembler source, and depending on your keenness, interest, size, etc you could probably get the whole or salient parts to rebuild.
Got cross-referencing ARM/THUMB disassemblers here that can ingest .HEX files.
