Hello, I have a Problem with my Nucleo F413ZH Board. I want to use a standard Timer 6 or 10. Clocksorce APB1or2 9MHz, Prescaler 60000-1 equals f=150Hz, Counter Period 13499 it should take 90s to count. But the PeriodElapsedCallback ocures after 10sec?
‎2023-01-26 6:51 AM
‎2023-01-31 4:49 AM
OMG... I verified this in a new project and it worked.
Source of my problem was the IWDG i programmed but never set back... So the Programm restarted after his time Period. But also we had to set the APB frequence higher since with under 1MHz it wouldnt work.
Kind regards
John
‎2023-01-26 7:33 AM
If I write 1500 as Counter Period I get 10s but if I put in 13499 I geht around 33s now... how is this possible?
‎2023-01-26 7:47 AM
Hello @JR46​ and welcome to the Community,
As you may know, the Counter Period is directly related to the frequency of the timer.
When the Counter Period is higher, the frequency of the timer is lower, leading to longer periods of time. This is based on the equation used to calculate the frequency, which is
F = 1 / (Counter Period * Timer Clock).
so when you increase the Counter Period, the frequency decreases, leading to longer periods of time.
‎2023-01-30 2:32 AM
Hello @Sarra.S​ thank you for the fast response.
Ok now I think I understand. And F is the frequency in which the Interrupt of the Timer ocures?
Kind regards
John
‎2023-01-31 12:47 AM
sadly your tip did not realy help me.
Even if I change my ARR/Timer Period it has no effect onn the Time tille the Interrupt ocures...
How is this possible?
Kind regards
John
‎2023-01-31 4:49 AM
Kind regards
John
