Hello, I am connecting a DHT22 temperature sensor to STM32F103C8T6 microcontroller. I am using HAL and reading temperature and humidity data from serial uart, on a terminal on my PC.
JWang.29
Please assist on how to resolve this. because if I deploy in the field it is not possible to be hard resetting every time for data to start streaming.
Thank you.
1 REPLY 1
Karl Yamashita
Lead III
You haven't indicated exactly what the issue is
Don't worry, I won't byte.
TimerCallback tutorial! | UART and DMA Idle tutorial!
