Hello, I am a novice, I want to use rs232 to communicate with the computer in stm32f072cb,I want to enter 123 and post 456。I use PA9, PA10 is TX, RX
Hjing.1
  * @file    01_Transmitter/main.c
  * @author  MCD Application Team
  * @version V1.2.0
  * @date    19-June-2015
  * @brief   This code example shows how to configure the GPIOs and USART1
  *          in order to send bytes.
                    #####       MCU Resources     #####
   - RCC
   - GPIO PA9(USART1_TX),PA10(USART1_RX),PA0,PC8,PC9
   - USART1
   - EXTI
                    ##### How to use this example #####
   - this file must be inserted in a project containing  the following files :
      o system_stm32f0xx.c, startup_stm32f072xb.s
      o stm32f0xx.h to get the register definitions
      o CMSIS files
                    ##### How to test this example #####
   - Plug cable " USB to TTL 3V3 " (from FTDIChip), to PA9 and PA10.
   - Launch serial communication SW on PC
   - Launch the program
   - Press the user button
   - "ST" is transmit to PC
   - The green LED should toggle if everything goes well
     (transmit request)
  * @attention
  * <h2><center>&copy; COPYRIGHT 2015 STMicroelectronics</center></h2>
  * Licensed under MCD-ST Liberty SW License Agreement V2, (the "License");
  * You may not use this file except in compliance with the License.
  * You may obtain a copy of the License at:
  *        http://www.st.com/software_license_agreement_liberty_v2
  * Unless required by applicable law or agreed to in writing, software
  * distributed under the License is distributed on an "AS IS" BASIS,
  * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
  * See the License for the specific language governing permissions and
  * limitations under the License.
#include "stm32f0xx.h"
/** @addtogroup STM32F0_Snippets
uint8_t send = 0;
const uint8_t stringtosend[] = "ST\n";
void Configure_GPIO_LED(void);
void Configure_GPIO_USART1(void);
void Configure_USART1(void);
void Configure_GPIO_Button(void);
void Configure_EXTI(void);
/* Private functions ---------------------------------------------------------*/
  * @brief  Main program.
  * @param  None
  * @retval None
int main(void)
  /*!< At this stage the microcontroller clock setting is already configured,
       this is done through SystemInit() function which is called from startup
       file (startup_stm32f072xb.s) before to branch to application main.
       To reconfigure the default setting of SystemInit() function, refer to
       system_stm32f0xx.c file
  Configure_GPIO_LED();
  Configure_GPIO_USART1();
  Configure_USART1();
  Configure_GPIO_Button();
  Configure_EXTI();
  /* Start transmission in button IRQ handler */
  /* Infinite loop */
  while (1)
  * @brief  This function :
             - Enables GPIO clock
             - Configures the Green LED pin on GPIO PC9
             - Configures the Orange LED pin on GPIO PC8
  * @param  None
  * @retval None
__INLINE void Configure_GPIO_LED(void)
  /* Enable the peripheral clock of GPIOC */
  RCC->AHBENR |= RCC_AHBENR_GPIOCEN;
	RCC->AHBENR |= RCC_AHBENR_GPIOBEN;
  /* Select output mode (01) on PC8 and PC9 */
  GPIOC->MODER = (GPIOC->MODER & ~(GPIO_MODER_MODER8 | GPIO_MODER_MODER9)) \
                 | (GPIO_MODER_MODER8_0 | GPIO_MODER_MODER9_0);
	GPIOB->MODER = (GPIOB->MODER & ~(GPIO_MODER_MODER2 )) \
                 | (GPIO_MODER_MODER2_0 );
             - Configures the USART1 pins on GPIO PB6 PB7
  * @param  None
  * @retval None
__INLINE void Configure_GPIO_USART1(void)
  /* Enable the peripheral clock of GPIOA */
  RCC->AHBENR |= RCC_AHBENR_GPIOAEN;
  /* GPIO configuration for USART1 signals */
  /* (1) Select AF mode (10) on PA9 and PA10 */
  /* (2) AF1 for USART1 signals */
  GPIOA->MODER = (GPIOA->MODER & ~(GPIO_MODER_MODER9|GPIO_MODER_MODER10))\
                 | (GPIO_MODER_MODER9_1 | GPIO_MODER_MODER10_1); /* (1) */
  GPIOA->AFR[1] = (GPIOA->AFR[1] &~ (GPIO_AFRH_AFRH1 | GPIO_AFRH_AFRH2))\
                  | (1 << (1 * 4)) | (1 << (2 * 4)); /* (2) */
  * @brief  This function configures USART1.
  * @param  None
  * @retval None
__INLINE void Configure_USART1(void)
  /* Enable the peripheral clock USART1 */
  RCC->APB2ENR |= RCC_APB2ENR_USART1EN;
  /* Configure USART1 */
  /* (1) oversampling by 16, 9600 baud */
  /* (2) 8 data bit, 1 start bit, 1 stop bit, no parity */
  USART1->BRR = 480000 / 96; /* (1) */
  USART1->CR1 = USART_CR1_TE | USART_CR1_UE; /* (2) */
  /* polling idle frame Transmission */
  while((USART1->ISR & USART_ISR_TC) != USART_ISR_TC)
		/* add time out here for a robust application */
  USART1->ICR |= USART_ICR_TCCF;/* clear TC flag */
  USART1->CR1 |= USART_CR1_TCIE;/* enable TC interrupt */
  /* Configure IT */
  /* (3) Set priority for USART1_IRQn */
  /* (4) Enable USART1_IRQn */
  NVIC_SetPriority(USART1_IRQn, 0); /* (3) */
  NVIC_EnableIRQ(USART1_IRQn); /* (4) */
             - Configures the Push Button GPIO PA0
  * @param  None
  * @retval None
__INLINE void Configure_GPIO_Button(void)
  /* Select mode */
  /* Select input mode (00) on PA0 */
  GPIOA->MODER = (GPIOA->MODER & ~(GPIO_MODER_MODER0));
  * @brief  This function configures EXTI.
  * @param  None
  * @retval None
 __INLINE void Configure_EXTI(void)
  /* Configure Syscfg, exti and nvic for pushbutton PA0 */
  /* (1) PA0 as source input */
  /* (2) unmask port 0 */
  /* (3) Rising edge */
  /* (4) Set priority */
  /* (5) Enable EXTI0_1_IRQn */
  SYSCFG->EXTICR[0] = (SYSCFG->EXTICR[0] & ~SYSCFG_EXTICR1_EXTI0) | SYSCFG_EXTICR1_EXTI0_PA; /* (1) */
  EXTI->IMR |= EXTI_IMR_MR0; /* (2) */
  EXTI->RTSR |= EXTI_RTSR_TR0; /* (3) */
  NVIC_SetPriority(EXTI0_1_IRQn, 0); /* (4) */
  NVIC_EnableIRQ(EXTI0_1_IRQn); /* (5) */
/*            Cortex-M0 Processor Exceptions Handlers                         */
  * @brief  This function handles NMI exception.
  * @param  None
  * @retval None
void NMI_Handler(void)
  * @brief  This function handles Hard Fault exception.
  * @param  None
  * @retval None
void HardFault_Handler(void)
  /* Go to infinite loop when Hard Fault exception occurs */
  while (1)
  * @brief  This function handles SVCall exception.
  * @param  None
  * @retval None
void SVC_Handler(void)
  * @brief  This function handles PendSVC exception.
  * @param  None
  * @retval None
void PendSV_Handler(void)
  * @brief  This function handles SysTick Handler.
  * @param  None
  * @retval None
void SysTick_Handler(void)
  * @brief  This function handles EXTI 0 1 interrupt request.
  * @param  None
  * @retval None
void EXTI0_1_IRQHandler(void)
  EXTI->PR |= 1;
  /* start USART transmission */
  USART1->TDR = stringtosend[send++]; /* Will inititiate TC if TXE */
  * @brief  This function handles USART1 interrupt request.
  * @param  None
  * @retval None
void USART1_IRQHandler(void)
  if((USART1->ISR & USART_ISR_TC) == USART_ISR_TC)
    if(send == sizeof(stringtosend))
      send=0;
      USART1->ICR |= USART_ICR_TCCF; /* Clear transfer complete flag */
      GPIOC->ODR ^= GPIO_ODR_8 ; /* Toggle Green LED */
			//GPIOB->ODR ^= (1<<2) ;
    else
      /* clear transfer complete flag and fill TDR with a new char */
		//	GPIOB->ODR ^= (1<<2) ;
  else
      NVIC_DisableIRQ(USART1_IRQn); /* Disable USART1_IRQn */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
5 REPLIES 5
KnarfB
Principal III
The basic (polling) pattern for sending at register level is
while( !(USART1->ISR & USART_ISR_TXE) );​  // wait for TXE flag being set (TDR available)
USART1->TDR = '*';​ // send 1 char
the basic (polling) pattern for receiving is:
while( !(USART2->ISR & USART_ISR_RXNE) );  // wait for RXNE flag (RDR not empty) being set
char c = 0xFF & USART2->RDR;
Check the reference manual for the flags and registers
Good luck
KnarfB
What are the symptoms?
Try to single-step through program in debugger and observe the relevant registers. Place breakpoints into the interrupts and check if they work as expected.
Andrew Neil
Evangelist III
Do you really mean RS232 - ie, with +/-12V signal levels?
If so, do you have a proper RS232 transceiver (sometimes called "level shifter") in place?
Sorry!!​
I want to change my button to PA8 and return "HELLO" from my computer,
where should I change it?
please
You should understand the code you have posted. Then, it will become very clear to you what to change.
