2023-01-20 03:57 AM
can somebody tell me, how to do it
2023-01-20 05:23 AM
Hello @MDevi.1,
The date format of YY-MM-DD is not supported by FATFS.
I think, as a solution, you can use the underscore character as the delimiter instead. For example, your folder name could be YYMM_DD.
Hope that helps!
2023-01-20 05:23 AM
Hello @MDevi.1,
Hope that helps!
2023-01-21 03:55 AM
Thank you for reply, it is worked .
