have interrupt after a jump
Options
2010-09-29 1:40 AM
Posted on September 29, 2010 at 10:40
1 REPLY 1
Options
2011-05-17 5:09 AM
Posted on May 17, 2011 at 14:09
If your boot loader and application code are in separate regions of flash, and each has it's own startup/interrupt vector table you will need to relocate/set the address the NVIC uses.
The boot loader needs to turn off interrupts it enabled, or transfer control/information about them to the application. Interrupts are certainly workable in both.
