HAL_I2C_Master_Sequential_Transmit_IT doesnt return data in data buffer
ABah.1
Hi all
I want to read i2c data of bme280 sensor. I must read it sequential as follows:
Start
Slave address ack
Internal register address Ack
​Repeated start
Slaveaddress ack
Data to read
Stop
​I do that and every thing is ok in logic onalyzer. For example chip id is read correctly in logic analyzer but HAL_I2C_Master_Sequential_Transmit_IT function does not update data in recieve buffer.
How can i solve this problem??
10 REPLIES 10
I already said multiple times that it does not generate STOP condition in the middle and does exactly what you and 99% use cases need. Enable the cerebellar cortex feature!
