HAL_FLASHEx_Erase Problem
Bahadir(Canceled)
Hello everyone !
I am converting one of the my projects from F0 to G0. While debugging, when i come to HAL_FLASHEx_Erase line, it jumps to HardFault. I checked the memory, flash address is empty. I don't erase the program. Here is the some picture during the debug session and code.
What is the problem or my fail?
//-------Error flags after the Erase function
int flash_par_adr1[ParSize] __attribute__((at(0x0800F000)));	// 4096 Byte =4KB
int flash_par_adr2[ParSize] __attribute__((at(0x0800E000)));	// 4096 Byte =4KB
//_____________________________________________________________________________ SaveParamToFlash
HAL_StatusTypeDef SaveParamToFlash(int page)
uint32_t tFlashAddress	= 0x00;
uint32_t tParAddress		= 0x00;
FLASH_EraseInitTypeDef	FLASH_EraseInit;
uint32_t								PageError;
HAL_StatusTypeDef				feedback;
	if(page == 0)
		FlashAddress= (uint32_t)&flash_par_adr1;
	else
		FlashAddress= (uint32_t)&flash_par_adr2;
/* Erase the FLASH pages */
	ParAddress	= (uint32_t)∥
	EndAddress	= ParAddress + ParSize;
	NbrOfPage		= (EndAddress - ParAddress) / FLASH_PAGE_SIZE + 1;
	FLASH_EraseInit.TypeErase		= FLASH_TYPEERASE_PAGES;
	//FLASH_EraseInit.Banks				= 0x00;
	FLASH_EraseInit.Page	      =	FlashAddress;
	FLASH_EraseInit.NbPages			= NbrOfPage;
	HAL_FLASH_Unlock();
  __HAL_FLASH_CLEAR_FLAG(FLASH_FLAG_EOP | FLASH_FLAG_OPERR | FLASH_FLAG_WRPERR | FLASH_FLAG_PGAERR | FLASH_FLAG_MISERR | FLASH_FLAG_PGSERR | FLASH_FLAG_FASTERR);
	feedback = HAL_FLASHEx_Erase(&FLASH_EraseInit,&PageError);
	HAL_FLASH_Lock();
	if(feedback != HAL_OK)
		return(feedback);
/* Program the user Flash area word by word*/
	tFlashAddress	= FlashAddress;
	tParAddress		= ParAddress;
	HAL_FLASH_Unlock();
	while ((tParAddress < EndAddress) && (feedback == 0))
		feedback = HAL_FLASH_Program(FLASH_TYPEPROGRAM_FAST,tFlashAddress, *(__IO uint32_t *)tParAddress);
			return(feedback);
		tFlashAddress	= tFlashAddress + 4;
		tParAddress		= tParAddress + 4;
	HAL_FLASH_Lock();
/* Check if the programmed data is OK */
    if (*(__IO uint32_t *)tParAddress	!= *(__IO uint32_t *)tFlashAddress)
			feedback = HAL_ERROR;
	return(feedback);
4 REPLIES 4
Guru
Why is this commented out? You need to initialize this field.
This is asking for a page, not an address.
Print out the values in FLASH_EraseInit at the time of the call to HAL_FLASHEx_Erase.
Thank you for reply TDK !
Actually I used codes which worked on F0. I guess i am missing something.
I will try on Monday what you suggest.
Bahadir(Canceled)
SOLVED...
First of all thank you @TDK​ you opened my eyes !
It is not PageAddress it is Page as you said so I added this code my function to calculate page number.
uint32_t  FlashPage;
FlashPage = (FlashAddress & 0x000FFFFF) / 0x800 ;
After that, I added this code below all of the flash operations.
FLASH_WaitForLastOperation(1000);
And it SOLVED. Whole codes below for anyone who needs help.
uint32_t								PageError;
uint32_t  FlashPage;
	if(page == 0)
	else
	ParAddress	= (uint32_t)&PAR;
	EndAddress	= (uint32_t)ParAddress + ParSize;
	NbrOfPage		= (uint32_t)(EndAddress - ParAddress) / FLASH_PAGE_SIZE + 1;
	FLASH_EraseInit.Page	      =	FlashPage;
  |  FLASH_FLAG_PGSERR  );
  HAL_FLASH_Unlock();
	HAL_FLASH_Lock();
		return(feedback);
	HAL_FLASH_Unlock();
		feedback = HAL_FLASH_Program(FLASH_TYPEPROGRAM_DOUBLEWORD,tFlashAddress, *(__IO uint64_t *)tParAddress);
			return(feedback);
		tFlashAddress	= tFlashAddress + 8;
		tParAddress		= tParAddress + 8;
	HAL_FLASH_Lock();
	return(feedback);
Also;
void LoadParamFromFlash(int page)
	ReloadWDT();
	if(page == 0)
	else
  while (ParAddress < EndAddress)
		*(__IO uint64_t *)ParAddress	= *(__IO uint64_t *)FlashAddress;
    FlashAddress	= FlashAddress + 8;
		ParAddress		= ParAddress + 8;
    __NOP();
  FLASH_WaitForLastOperation(2500);
