HAL_ERROR when i try to erase the flash memory
FVarg.1
Hello, i'm using STM32G071RB and i need to write on the Flash Memory.
i check if i have wrote on it before. If i did, i try erase the page to re-write. At this point, i just get a HAL_ERROR of the function HAL_FLASHEx_Erase(&EraseInitStruct, &PageError).
i'm doing this:
#define FLASH_USER_START_ADDR  0x08000000
#define USEDPAGES ((uint8_t) 64)
HAL_FLASH_Unlock(); //Unlock memory write permission
FLASH_EraseInitTypeDef EraseInitStruct;
/**Define Erase Struct**/
EraseInitStruct.TypeErase = FLASH_TYPEERASE_PAGES;
EraseInitStruct.Page = FLASH_USER_START_ADDR;
EraseInitStruct.NbPages = USEDPAGES;
if (HAL_FLASHEx_Erase(&EraseInitStruct, &PageError) != HAL_OK){//Erase Pages
printf("Fail Init Erasing\n");
return 0;
i did the same funtions with stm32f0 and i had no troubles with it
2 REPLIES 2
It needs a page number, not an address.
See an example here:
https://github.com/STMicroelectronics/STM32CubeG0/blob/5cb06333a6a43cefbe145f10a5aa98d3cc4cffee/Projects/STM32G071B-DISCO/Examples/FLASH/FLASH_EraseProgram/Src/main.c
Also in the code:
  * @brief  FLASH Erase structure definition
typedef struct
  uint32_t TypeErase;   /*!< Mass erase or page erase.
                             This parameter can be a value of @ref FLASH_Type_Erase */
  uint32_t Banks;       /*!< Select bank to erase.
                             This parameter must be a value of @ref FLASH_Banks
                             (FLASH_BANK_BOTH should be used only for mass erase) */
  uint32_t Page;        /*!< Initial Flash page to erase when page erase is enabled
                             This parameter must be a value between 0 and (FLASH_PAGE_NB - 1) */
  uint32_t NbPages;     /*!< Number of pages to be erased.
                             This parameter must be a value between 1 and (FLASH_PAGE_NB - value of initial page)*/
} FLASH_EraseInitTypeDef;
Ons KOOLI
Senior III
Hi @FVarg.1​ ,
Please refer to the FLASH_EraseProgram example under directory STM32Cube_FW_G0_V1.4.0\Projects\NUCLEO-G071RB\Examples\FLASH of the STM32CubeG0.
Best Regards,
Ons.
Note: If the problem is resolved, please mark this topic as answered by selecting Select as best. This will help other users find that answer faster.
