2008-11-03 3:28 PM
GCC toolchain compling errors
2011-05-17 3:50 AM
Hi
I am using CodeSoucery G++ tool chain for my STM32 project. I setup my GCC environment by following this website: http://sites.google.com/a/stf12.net/developer-sw-fw/eclipse-demo When I tried to build my project, I got below error messages: c:/program files/codesourcery/sourcery g++ lite/bin/../lib/gcc/arm-none-eabi/4.3.2/../../../../arm-none-eabi/lib/thumb2\libc.a(lib_a-sbrkr.o): In function `_sbrk_r': sbrkr.c:(.text+0x12): undefined reference to `_sbrk' c:/program files/codesourcery/sourcery g++ lite/bin/../lib/gcc/arm-none-eabi/4.3.2/../../../../arm-none-eabi/lib/thumb2\libc.a(lib_a-writer.o): In function `_write_r': writer.c:(.text+0x16): undefined reference to `_write' c:/program files/codesourcery/sourcery g++ lite/bin/../lib/gcc/arm-none-eabi/4.3.2/../../../../arm-none-eabi/lib/thumb2\libc.a(lib_a-closer.o): In function `_close_r': closer.c:(.text+0x12): undefined reference to `_close' c:/program files/codesourcery/sourcery g++ lite/bin/../lib/gcc/arm-none-eabi/4.3.2/../../../../arm-none-eabi/lib/thumb2\libc.a(lib_a-fstatr.o): In function `_fstat_r': fstatr.c:(.text+0x14): undefined reference to `_fstat' c:/program files/codesourcery/sourcery g++ lite/bin/../lib/gcc/arm-none-eabi/4.3.2/../../../../arm-none-eabi/lib/thumb2\libc.a(lib_a-isattyr.o): In function `_isatty_r': isattyr.c:(.text+0x12): undefined reference to `_isatty' c:/program files/codesourcery/sourcery g++ lite/bin/../lib/gcc/arm-none-eabi/4.3.2/../../../../arm-none-eabi/lib/thumb2\libc.a(lib_a-lseekr.o): In function `_lseek_r': lseekr.c:(.text+0x16): undefined reference to `_lseek' c:/program files/codesourcery/sourcery g++ lite/bin/../lib/gcc/arm-none-eabi/4.3.2/../../../../arm-none-eabi/lib/thumb2\libc.a(lib_a-readr.o): In function `_read_r': readr.c:(.text+0x16): undefined reference to `_read' collect2: ld returned 1 exit status cs-make: *** [IOM_ACQ.elf] Error 1 I spend some effort to figure out those errors caused by sprintf() in my code. But I don't know why I can't call c library? I searched some arm forum about this topic, some people mentioned about syscalls.c. Does anybody know this issue? If it does need a syscalls.c, does anybody can give a sample code?2011-05-17 3:50 AM
you are working with a barebone machine so the newlib needs some minimal support in order to allocate memory and perform I/O tasks. You should provide replacement for some syscalls normally provided by the OS, read this article: Most functions are just stubs, the sbrk() should be implemented in order to make the allocator work (probably the sprintf() allocates memory internally). regards, Giovanni --- ChibiOS/RT2011-05-17 3:50 AM
Hi Giovanni
Thanks for help. the link you provided clarifies systemcall functionality. Since I am more familiar with hardware stuff other than software, this document is good for me. I have solved the problem to use GCC library in my project. I found this link provided good details about how to write syscalls.c and how to define 'end' in link script: http://forum.sparkfun.com/viewtopic.php?t=5390&start=15 Now my code has been complied without errors! :p Regards, JZ
